Re: I've never been a fan of electric cars.....
Which is why I’d not say you’re a skeptic.
As I said there are draw backs to electric cars and while some make them a massive problem or barrier, others like your self try to work around them
All comes down to safety, has nothing to do with electric cars, pitch a 1960’a fiat 500 against a 2020 version in a head to head collision and you’ll soon see why they don’t make the small cars like they use to.
At least the 500 has a reasonably useable range.
Go back an read what g8rpi said
“ You cannot compare batteries in consumer items with those in EVs. The batttery management in EVs ensures that they are never over discharged or over charged.
Over discharging and over charging cells is very harmful to them. Due to the size and cost of EV batteries they are never charged or discharged to their maximum capacity. The slight loss in range per charge is far outweighed by the dramatic increase in battery life. With a torch, drill, cellphone etc the working life and cost of the item means using the full battery capacity at the expense of life is appropriate.”
New iPhone batteries do last and work a lot better than they did on the iPhone 6 and 6s which is the model that caused a lot of controversy with rapidly losing capacity and shutting down in use.
New iPhones (like the one I own now) will stop charging in the night at 80% and then will intelligently charge the last few percent in the hour before you are due to wake. You can also set some goods to not fully charge, my laptop (Lenovo) will do this and the battery is still good in that after 3 years.
Seriously rather than making assumptions go and do some research into this and you’ll see that after 100,000 miles electric cars see very little degradation in the battery. Most manufacturers will give an 8 year battery warranty, no one is going to give a life time warranty on a battery but if you buy a car new then what’s the likelihood most people won’t have replaced it twice by 8 years.
An electric drill will wreck its battery and at £50 a time for a replacement it’s not a bad cash cow for the makers, but when you up that to £8k for a new electric car battery suddenly you find consumers are not going to buy your car if it does destroy its own battery.
Tesla tried the battery swap system, it didn’t work and it’s expensive.... very very expensive, also who owns the battery in that situation, who is liable of the battery breaks down. It’s very difficult to swap electric car batteries out mainly because they weight hundreds of KG. It’s a kin to suggesting rather than fill your tank with petrol you swap a full tank for the empty tank every time you go to the petrol station. New electric cars will charge to 80% range in under an hour and if charging the car at home, most would not need to charge away from home unless on a very long journey, in which case you’ll plan your charge stops. After 200 miles of driving most people would want to stop for a coffee and something to eat.
Perhaps a bit overkill, I can’t see anything I JRKitching’s post to warrant that?
True..
But I'd been talking about getting a Renault![]()
What really irritates me is the awful habit of making cars bigger, wider, heavier with each new release. I accept the weight increase in an electric car, but otherwise cars should rater get smaller than bigger, space in the streets is the biggest problem these days.![]()
And most of the time, it's only 1 person in the car these days while the old 500 used to carry families with 3 kids.:
sadly in the Mini (at least at the moment) they only have one battery size with a relatively small range, then again maybe that’s clever and they know most people as you point out will only use them round town ?For me, one of the clever aspects of the new 500 is giving buyers the choice of battery size. Like the Mini, many 500s are used as a second cars or city cars, so the cheaper, smaller battery version will be fine. Those who use it for longer runs will have to spend extra, but at least there is the option.
Not sure I was 'claiming' anything re batteries just passing my opinion why I am not ready for an electric car from experience with many other items that the batteries just don't last
I appreciate rechargeable batteries have come a long way over the years and if what you say is correct then the battery could/should then be given a lifetime warranty and that would be a good starter. Lots of complaints though still live online re Apple iPhone battery life so why should we believe the car industry has suddenly got it all sussed out.
That is probably the worst comment I have ever seen.....and from a moderator....tell you what I will just leave the forum
