Technical Is there an Auto electrician genius who can help?
millymoon
Hi, I've got several previous posts on here, but have had to keep abandoning the project. All I need now is if someone can identify which electrical wire from the ECU feeds the Turbo Actuator on a 2001 Fiat Multipla 1.9 JTD ELX. Turbo actuator not working and I've been strongly informed this is the solution. Really do not want to go through the entire wiring loom if I can avoid it! :bang: I have a diagram of the ECU/wiring but cannot identify specifics.. so not much help really!
Any help/thoughts at all will be very gratefully recieved... :D
Hi, can anyone help identify which wire goes between the ECU and the turbo actuator??? All thoughts/help very gratefully received
