Hello guys...this morning I started my Panda which has been parked out of my garage this night, and I noticed it didn't want to do itB)!After the 3rd attempt I pressed a little bit the accelerator and it started even if running with 3 cylinders (my opinion
)...this went on for a couple of second and then the engine kept on running fine as usual[8D],and the problem hasn't reappeared!This is the 1st time it shows problems, I thought it could be some water in the cylinders due to an head gasket gone, but there aren't signs of that failure
...no coolant loss and creamy deposits!The spark plugs have only 5000km...the cables and distibutor cap are old but the rubber's still soft,maybe they cause problems with low temperatures and high humidity[:0]?Any advice will be appreciated...
