General Interscope Sub & Amp
Noup, sub is amplified, amp is built in the enclousure..you have to connect sub out from android radio to signal inputs of the underseat sub..
The problem is that the sub doesn't have a separated input.
My sub is in the trunk, near the amplifier, inside the same enclosure.
I found the Interscope scheme for Fiat 500, I believe it is the same as on my Bravo. Please take a look on the attached PDF.
There are 7 inputs to sub, I believe it is a sub module. One input is Ground, the others are RB, VC, CL, RG, VR, CH. :bang: :worship:
But I can just disconnect the sub speaker and connect it directly to sub out from android radio.
What do you think?
  • Interscope Sub & Amp - Fiat 500.pdf
