Styling Interior l.e.d
Can I be a pain in the ar$e and ask for a pic of the front lights too?
The cables don't go into the lights. Only the LED's do. And the cables connect to the back of the LED's and then to the powere source. So the cables sit outside of the bulb housing. All will become very clear once you actually have them in front of you
It's normally power cable directly into bulb and the bulb pushes into the lights what you do is take power cable out of bulb, stick resistor into power cable and the new LED into the other end of the resistor and stick the LED into the bulb housing leaving the cables dangling out the back
Normally
Power cable - bulb into light housing
Modified
Powe cable - resistor - LED into light housing
Here we go
Then you plug the resistor into last picture which gives you an inline resistor which has a connection on the other end which is where your bulb goes.
you then push the bulb back into the diffuser it came out of then you got the second picture
just push the resistor up into the space and then your left with the first picture
Don't fret if they don't work first time. They are one way fit only so you may need to flip the connectors until they work, and watch the resistor and bulbs they get hot pretty freaking quick.
Top tip dude breaking it down if it don't work turn the bulb around 180 degrees just trying to make it idiot proof.
Once all this is done turn your ignition key on and it will come up check number plate lights don't go biting the steering wheel turn it again to main beam then off and it won't come up again as if it's registered the fault being fixed
Dude it is a 5 min job but looks worse as trying to make it simple for you
Here's a few pictures of my interior lights. Not that great photos though. They really don't do them justice
Very cool. Always loved blue lights. I'd do it to every light in the car if I had the foggiest how to do it.
Thanks there supposed to be white and am the same as you i had the whole dash out with intensions of chamgin all the bulbs and soon found out that everythin is soldered on leds lol the only bulbs are the heater control panel lol and even then you can only change 2 bulbs
Oh I can see they're white mate sorry. My post was unclear. I just meant to say I like blue bulbs they look brilliant.
Yes I thought as much, they're all soldered onto chip boards. With patients and the right tools I bet it's pretty easy if not fiddly, but I'd rather not risk it to be honest.
Lol its fine :) and yip its a pain to get all the bits out and i was thinkin about doin some diggin onlube to see if there was some boffin out there that could replace the little leds thats on the circuits
Funny you should say that. It actually does, and the LEDs I've fitted do it brilliantly. They're on just enough so you can see but not enough to distract you. And because they're LEDs they have a soft blue colour to them which looks fantastic'
Know this is a bit late, but my bravo doesn't have them, and would really like some! Do you think it's just a matter of replacing the interior light for one that has LEDs? Some nice dark red ones would really add the final touch! :D
A wee update of my own for the interior side of things
Hi mate ,can i ask how u removed the heater controls for the bulbs ,mine are gone ,i tried a while ago ,had everything above them and everything below them removed ,car in pieces and still couldnt get to them , thanks
