Fairly obviously you will need all the parts from the ac system, compressor, condenser, pipes fill ports wires any mounting brackets for the compressor, then in the car you’ll likely need the whole heater box dash wiring loom and switches.
As also stated above you may need the engine ECU which may also mean you need the body computer and any other bits of the immobiliser system unless you have the means to reprogram this
It is a lot of work best broken down into chunks over several days or weeks depending on how much time you have to dedicate to it.
If you have a donor car with everything installed then it might be worth just swapping everything over to the good car strip all the wiring looms from the car and move it over. Alternatively if it’s just the engine that is bad in the donor, moving your good engine over to the donor car would probably take about a day
