Technical Increasing Hazard Light/Turn Signal volume
kourampies
Patras
I have a Delta III which is almost identical to the Bravo.
The turn signal clicking is barely audible with the engine turned off, with the engine running its impossible to hear it, and I'm constantly forgetting the hazard lights on.
I know that this is the way most Fiat cars are designed (had the same issue on my 147, a little better but still low on the wife's 500), but on the Delta its extremely low.
If I understand correctly the clicking is electronically generated and not an actual relay sound. Is this true, and can it be improved somehow without any hardware mods?
Or if a hardware mod is needed, can it be done from internal fusebox or something like that, without tapping wires from turn signal bulbs etc?
