dangfiat
Hi All,
A little story about my continuing adventures. Apologies for the length, and I know this ignition thing has been done to death but I have questions.....
My little Fiat (with a 650cc) has stopped running: won't start or even try to catch.
1. I replaced the points (gapped to .48mm), & the condensor. Had to pull the distributer to do it.
2. I got the motor to the TDC mark, put the dizzy in with the rotor pointing straight at the block. Rotated to the 10degree mark, spun the dizzy so a test light showed the points
3. Pull the starter switch.... no fireing, not even a catch
4. I think "what if I'm on the wrong TDC?"..... So I switch the plug leads at the distributor cap (switch 1 & 2 around)
5. Fired right up! YAY!!....... Wouldn't rev (would die with anything but gentle throttle) and made backfire noises. Drove up the street and the engine just died, cut out. No starting. NO JOY, I was a sad sad Dan (also a tired Dan... even this little car is annoying to push for a block or two
6. So... I've replaced the condensor (again) and flipped the distributor around, retimed it. Nothing, no start, no nothing. Won't start
I'm off to replace the coil next. Darn thing is waaaaay back in the left side of the engine bay. Should be exciting getting in there!
Question (Finally!!!): How do you tell what cylinder is at TDC when on the timing mark? I assume the rearmost cylinder is #1?
Thanks everybody, I'll get this little dragon back to breathing fire yet!
Daniel
Daniel
