Technical I have a qubo vehicle that does not change gear. I changed the transmission oil. What could be the problem? It has an automatic transmission
fiatteona
usa
I have a qubo vehicle that does not change gear. I changed the transmission oil. What could be the problem? It has an automatic transmission, 1.3 multijet.
Topluluk Tarafından Doğrulandı simgesi
Transmission oil.. In Gearbox..? 🤔
There Is a reservoir of clear fluid above the gearbox.. Have you checked that?
Often it leaks..😕 Needs Tutela "Selespeed fluid"
Check the brake light switch. Ensure it works when the pedal is pressed, and is not working when the pedal is released.
Then check the earth at the left rear lamp. (Might be the right for LHD vehicle.) The gearbox control unit seems to rely on an earth at the rear lamp. Has caused Panda and Punto owners grief.
