I've noticed that the TwinAir 500 is supposed to weigh 1030Kg! This is much more than the 1.2 500's (165kg) dispite the engine being lighter. Does anybody know why this is or whether this is incorrect?
The 1.2 weighs 865kg'sI am guessing that the 1030 kg is the whole car, the 165kg just the engine in the 1242.
Having just seen the size of the HD battery in the TWINAIR I'm not surprised if it weighs more than the 1.2.
HD means Heavy Duty I'd guess?The what battery? The normal battery looks fairly normal.
Would the weight of the engine usually include the turbo? I would guess with the twinair being heavier (and of course smaller) that it would.Twinair 875 Mair Displacement: 875 cc
Bore x Stroke: 80.5 mm x 86 mm
Max Power: 85 HP (63 kW) @ 5500 rpm
Max torque: 155 Nm @ 2000 rpm
Dimensions (LxWxH): 307 - 500 - 596 mm
Mass (DIN – 70020A): 85 kg
FIRE 1242 MPI E4
Bore x Stroke: 70,8x78,9 mm
Power: 65 HP @ 5500 rpm
Torque: 104 Nm @ 3000 rpm
Dimensions (LxWxH): 475x442x595 mm
Mass: 84 KgExhaust port-driven swirl
http://www.fptpowertrain.com/eng/applicazioni_automotive_benzina_eu.htm#g03
FIRE 1242 MPI E4
It sounds like we've been mislead. Most articles say that it it is 7kg lighter than the 1.2 as well as being more powerful, but these figures suggest that it isn't. I suspect that the non-turbo is 7kg lighter than the 1.2, but it is also a lot less powerful.
It still doesn't explain where the other 164kg come from. It weighs a lot more than the 1.4, so even with bigger brakes and battery etc. it still wouldn't add up.
Edit: I've just noticed that those figures don't look right. Maximum torque is supposed to be 145Nm @ 1900rpm IIRC.
Does it really matter? As long as the car is economical that and the engine is good enough that's all that mattersI've found the answer to my initial question now. It weighs 930kg (got this from the handbook), which is the same as the 1.4. This is a lot heavier than I was expecting, but after reading something, I suspect that the weight Fiat keep talking about doesn't include the turbo. So the 65bhp one will probably be 7Kg lighter than the 1.2. It still seems like a very big increase though.
Does it really matter? As long as the car is economical that and the engine is good enough that's all that matters![]()
