most engine bores with wear are smooth.. but it is a mistake most people make to assume smooth is good.
When new, and rebored/honed the bores are actually cross hatched.
like, which is why even if the bore is in good condition, honing is good practice, because it breaks the smooth glaze and brings back the cross hatching which ensures a good seal.
Checking for wear, look for things like how much of a wear ridge there is around the top of the bore.. normally you get a ring around the top which is a few mm deep.
to properly check though would need to go to a specialist.
they measure accross 2 axis of the bore.
and
if both measurements are equal then the bore is round.. but if
is geater than the bore has gone oval shaped.. hard to measure accurately though without the proper measuring device as your talking measurements of less than a quarter of a mm and thats the problem, the old ring would of worn to the shape of the bore and would of itself become oval shaped. But because with a round piston ring, if the bore is oval shaped and the ring is round you have a gap on 2 edges as it would be a different shape to the bore.. so the compression inside the cylinder will be less than before you started.
In regards to the bearing shells.. yep its stamped on as a number, or STD for standard.
