It's a pain in the ass, but you have to depress the locking levers in the middle of the connectors, whilst pulling them out. I'm afraid if you have no more wire slack you have to get creative and brutal. All the white plastic is hidden when assembled back together so don't worry too much about damage. Work on the tightest connector first. Once it's released you may have more slack to get to the second. The big on is easiest to get a tool to. Drill a hole or 2 in the white plastic above. Just make sure no important cables or wires are there. The like a keyhole surgeon you can use something like an Allen key to push the tab down and a flat blade screwdriver to pry the connector out. It will be tight as it hasn't moved in 20 yrs. But when it starts to go it'll come easy. Then tackle the smaller one. You might have to take some of the white away on the right hand side and use the bent end of an Allen key to hook round and press the tab on that one.
Keep us updated of any progress. Pics would be good as well so we can see.
And after brutality with the the multi tool, the switch is goodBrilliant thanks will give it a go now![]()
Thanks for that, I have 12v motor plug to chassis earth, what are terminals in switch? 1-5 left to right looking from the back roound side up??With ignition switch on. Check for voltage at pin 1 of the motor plug. If present, reconnect and check for voltage at pin 5 of the big switch connector. If present check for good ground by doing resistance check pin 1 of the big switch connector to a known earth point such as the door strap bolts. Should be negligible resistance, if it is high that's your problem. Then you just got to follow the wire from the switch to find the bad connection.
For now I am connecting the 12v at motor plug with switch and running new earth, any suggestions for nearby earthing point, there is a bolt on top of the tunnel by handbrake that works?Thanks for that, I have 12v motor plug to chassis earth, what are terminals in switch? 1-5 left to right looking from the back roound side up??
Thanks for all the help, looks like a duff earth, confirmed by none of the heater control bulbs light up and they share common earth (found wiring diagram on here) .Wired in separate switch and earthed to body so have fan on max speed. For now may be foreverIf you're running a new earth make sure the wire gauge is good and chunky and any structural bolt will be ok to go to. You could even go a bit more pro and crimp on a ring tongue. But the crimps you get from Halfords etc. can be iffy you have to really make sure they can't pull off.
Thanks, I saw that post but can't see that type of connector, will have another look, thanks againCool glad you have some airflow now. I'm sure you're sick of it now, but if the urge to fix it to full functioning gets to you check this old guide. 100 to 1 this is the connector that's knackered, no need to strip the dash. Just cut the black wires either side of the connector and join together with crimp, choc block etc.
Mk2 - My sidelights come on instead of my interior fan!!!
Hello, A fairly common problem on the Punto Mk2 is the interior fan not working when the fan control nob is turned. If instead, your sidelights come on, then this guide is for you!! This is a 10 min job to fix, and all you will require is a...www.fiatforum.com
