Technical Hi my Beast 1.9 jtd diesel ( Multipla) has no injectors pulse while cranking, no faults found on diagnostics tool🤦‍♂️
Mnikazi
Kwadukuza
Hi my Beast 1.9 jtd diesel ( Multipla) has no injectors pulse while cranking, no faults found on diagnostics tool🤦‍♂️, quick start spray used, it started then shutoff. Ecu, immo box sent for technical support came back fine ,plugged them on , same results 🤦‍♂️ please help
Does the rev counter move when cranking, if not replace crankshaft position sensor.
Mil light come on with ignition on?
+1 to crank sensor as they often fail without giving a fault code.
Have you checked for an injector pulse ? And found none?
What is the diesel rail pressure when cranking?
