Technical Hex screw size
RJF
Luton
Need to know the Hexhead screw size for the heater resister fixings? Photo attached
Model
Punto multijet 1.3 diesel
Year
2013
Why? Wrong approach to the servicing (counterproductive). Just be prepared, buy a set of sockets and don't ask "what size" it is.
Small hexagonal heads like that can be: 4,5 / 5 / 5,5 / 6 / 7 mm for example.
Some are not metric (rare), so it's a 6,3-6,4 mm or so (so 1/4'' hex driver fits directly to the bolt, no sockets needed).
What a lovely reply, you must be very proud to be the owner of your socket set.
Anyway, thank you for your help it was greatly appreciated.
Most of the tiny hex heads I've encountered have been 5.5mm. Seems a strange size, until it compares almost exactly with 7/32".
Tiny socket sets are often easier to find in inch sizes, although the 7/32 seems to be the only one I've used in 40 years.
If you've got some Blu-tack, or similar, press it onto the head, and remove carefully. The indent should be measurable. Kids plasticene works well to, probably better, but chewing gum, not so much.
