Panda 2012+ help needed to do a proxy alignment
lakesbecks
Penrith
I am a newby to the site and just wanted to see if there was anyone who had the mutiecuscan set up to be able to do a proxy alignment for my Panda Treking 1.3D . The Blue and Me module failed, has been repaired but the data was apparently lost / corrupted so when reinstalled does the usual flashing odo business. Before I splash out on getting the set up and a laptop I was just interested to see if anyone locally had access to the correct kit and would be happy to help me do the proxy alignment. I live between kendal and Penrith so would be happy to drive elsewhere if there is a fiat owner who has access to the kit.
fingers crossed , or alternatively I may be after some tech help if I need to do this myself.
Check the MultiecuScan members in the Directory, there is a chap in Carlisle. Send him a message, might save you some hassle.
Any one in kent do proxy alignment
Hi yer I don't want to waist your time when I press the fone button the blue and me doesn't do any thing and the millage is flashing when I turn it on blue and me comes up on dash display I was just wondering if a proxy alinement might do it
Can you turn the blue and me off and delete module with mse
You would need to unplug the Blue & Me unit (or remove it completely) and then do a proxi alignment to remove it from the system. Odometer should then stop flashing.
OK thanks I've seen it done it looks a nightmare
Which bit ;) ? The unplugging bit is straightforward - the B&M unit is under the driver's seat (RHD version) and doing this will avoid the (likely) risk of a parasitic battery drain if the unit has failed. The MES bit I can't speak for having no experience of the hardware/software.
