Hi mate,
As above, check the fuse. The dipped beams have their own individual fuses (ie there are two) so make sure you check the one for the passenger side.
Failing that, check the multi-plug at the rear of the light unit. Remove it and inspect the pins for any tarnish/ corrosion.
Then check for power at the multi-plug connector with a multimeter. If you have power at the multi-plug, then check for power at the bulb connector, as I have known these head light units to fail internally.
Alan
