General  GTEC2 chip
General  GTEC2 chip
donny lad
doncaster
Just baught one of these and wanted to know if anybody has had any experience with them, only paid £25 so couldnt not buy it.
They're good. Do exactly what they say on the tin! One thing I'd recommend if you haven't got one is a boost gauge to make sure it doesn't over boost once fitted.
Also worth noting they do different versions including one with more aggressive mapping but you have to run it on high octane petrol. They also do a further aggressive one that is designed to go with other mods (Induction, Exhaust, FMIC) etc.
cool no worries.
which stage will i need when i fit the following to the engine?
Garret T3 turbo
FMIC
Decat
3" zorst
viper iduction kit
denso plugs
4bar fuel reg
ported inlet
well chip came today very speedy service i must admit. cant wait to get it in when i get a nice cheap ecu lol
What engine do you run? as I notice you've listed a T3 turbo as a modification, the 20VT engine has a T25 Flange and the T3 series won't fit. I wouldn't fit a GTEC 2 unless you have a FMIC, a GTEC 1 is a far safer bet. Better still would be a flea map!
Hi
I currently have:
FMIC
4bar fuel reg
Im awaiting some 440cc injectors
Ported inlet system
It will be having 3"decatted system made up to suitcar when its all built up too.
thats a bit of a shame like with the turbo lol i was told a T3 flange would fit but no matter i only paid pittence for it ill just whack it back up on ebay.
What other turbos are good cheap upgrades?
Cheapest would be a second hand hybrid T28, ranging from £200-500. Simple bolt-on upgrade using existing flange and no need for a V-Band adaptor (which you need for a ball bearing, turbo like the GT28RS) But I'd get a remap before that. I got an extra 50BHP from a Flea remap that cost £175 :eek: You can't beat that, works out less than £3 for every extra horsepower :D
What would happen if you used normal petrol with a chipped 20vt?
Apart from the chip its comptly standard and fueling was fine, it was on rollers at 259 but I was told it was ok to use normal fuel.
The chip was on the car when I bought it.
Thanks chrisuk, I must have the one the first one a sthe guy told me its cool to run it on normal fuel but I though it best to check.
Personaly id rather have remap, the chip will be comming off when I have all my bits and pieces to go with my garret t3 turbo with rollerbearing.
to be fair my cars runs great with the chip, no lumpy idle like i had with the evocars chip I was running on my 16vt.
Also I need to know if you need the colder spark plugs as I did with the evocrs chip on my 16vt?
