I inherited a Punto Mk1 (1.1 SX in 1994 flavour) that doesn't start... It's hardly a surprise since it's travelled about 150 miles in the last 6 years and zero in the last two. Otherwise it was running when it was last used...
I mean it wasn't broken down.
Anyways, I put a battery from an aircraft carrier in it and it cranks well but nothing else happens.
It tries to catch on aerosol "Easy Start" and the plugs have a spark.. so that bodes well but I don't get a strong smell of petrol from the injector area so I think the problem is the fuel pump.
When I turn on the ignition, I can't hear a "whine" and when I crank the engine, I only get the faintest little dribble from the pump "out" pipe (on the pump itself). New pump is on order...
However, to be sure I'm not barking up the wrong tree.. can anyone confirm how to check that the fuel cut-off switch isn't preventing the fuel pump from working? The switch is "On" (pressed in) so it looks okay but the connector on the fuel pump has 4 wires and I don't know how to test that there is a current there. Two wires are black, one looks beige, the other more yellow/orange.
I'd like to be sure the plug is "live".
There are no lights on the dash. The dash lights up as normal and then they all go out, including one that looks like an injector, apart from handbrake and charge/oil pressure, so that looks good to go.
Ta,
Ralf S.
Ta,
Ralf S.
