- Joined
- Mar 25, 2018
- Messages
- 277
- Points
- 174
Anyone point me in the direction of where it is on the 1.2 ( if it has one) and the part number ( if it has one) thanks
Yes, there is a filter.No fuel filter on any fiat petrol engine at least not in UK and most of Europe anyway
For petrol cars, its in the fuel tank and non-replaceable (so no part number)
For diesel, under the bonnet and long life.
There is also a charcoal filter in the fuel tank filler/breather (the so called 'evaporation canister'), that is replaceable but very very infrequently.
Why are you looking for one?
never serviced it so i just wondered if it had one.
Those gauze mesh devices are of course a filter by definition, but I would be amazed if there's not another proper fine filter somewhere in the system. As mentioned above, Injection needs VERY clean fuel and those dirty particles not picked up by the in-tank gauze will need to be stopped somewhere further down the line. Whilst I admit there's nothing obvious on any of the online parts schematics, I remain amazed if this is actually the case.
As it happens I have just had to replace the in-tank pump in my Morgan 3-Wheeler and the gauze was quite dirty, but clearly it doesn't catch everything as the pump motor failure was clearly down to debris damage. I also changed the MAHLE in-line fuel filter (about the size of a normal can of Red Bull) as a precaution, as it would have been dirty after 7 years and 20,000 miles.
My late father never believed that fuel filters needed changed - until his SJ410 Suzuki Jeep ground to a halt on the M23 with a completely blocked fuel filter. He started changing them after that....
So quite how our beloved Fiats keep running on trust that the fuel is clean is beyond me![]()
Older petrols had inlines tucked around the bodywork
Most will now have a filter built into the pump
there is a second filter on the injector rail where the fuel line connects. But again, not replaceable.Those gauze mesh devices are of course a filter by definition, but I would be amazed if there's not another proper fine filter somewhere in the system. As mentioned above, Injection needs VERY clean fuel and those dirty particles not picked up by the in-tank gauze will need to be stopped somewhere further down the line. Whilst I admit there's nothing obvious on any of the online parts schematics, I remain amazed if this is actually the case.
