Technical Fuel filler cap seal
Voko
Whitchurch, Hants
My fuel filler cap seal is perished and cracked, as a result it's a bit wiffy....would anyone know a source of a replacement that fits?
Mike
From what I can see on the Fiat parts info the fuel cap, with seal is a single unit.
However I suggest you look carefully at your fuel cap and extract the seal if possible.
It is very unlikely that the seal is a "one off" Barchetta only item and you should be able to source a replacement seal from a company that specialises in "O" rings and other types of seals.
Well it’s over 6 years since I posted this question, but as it popped up as an advisory on my otherwise perfect mot, I thought I’d do something about it!
I measured up and ordered these for Vauxhalls from Amazon https://amzn.eu/d/f1hIdmG and they fit perfectly 😃
WOW! Only 6+ years between posts! A record, possibly not, but at least you have found a part that others can look for in another 6+ years time.
Thank you for coming back to all of us! Very much appreciated and the info will be here on FF for all to find in the future.
