Technical Front Headlight & Headlight Bulb Fitting Clip + New Tires + Roof Rack
Black Betty
Palma
Hello, please help for this very silly small part.
I need a bracket for a headlight for my Fiat Panda Young. The garage went to change the bulbs in the headlights and order the headlight bulbs and they lost one of the brackets that holds the light/ bulb in place. Without the bracket, it will not pass the ITV test here in Spain. I cannot find this bracket in searching for some reason. Again I have one bracket but I am missing one bracket. So I need one bracket and 2 new headlight bulbs standard to the Fiat Young so it will pass the ITV. Image and model attached. I drew the bulb fitting clip to highlight what I need.
Also I want to get a new set more sturdy/ badass tires and a roof rack for my bike / surfboard. Suggestions of retailers and what I need. Sorry I'm a Panda and vintage car newbie. I had a 1998 Toyota 4Runner that never needed anything but new snow tires and a new battery ;)
Thank you for your help!
Model
141
I can find entire new front headlights but I just need this clip attached x 1. And new lightbulbs x 2.
Hello,
That could be a very difficult part to get. The spare parts catalogue doesn't list it as a separate part :(
Check the breakers and the internet (ebay?) for whole light clusters. Could be broken, damaged, then the side does not matter as you need only the metal clip.
For the bulbs, you should be able to find them anywhere. Back in the times I've swapped the bulbs in my FIAT 126 from the classic bubble to the H4, they were making the H4 bulbs with the P45t mounts (the mount for the classic bubble). The H4 were much lighter with same wattage.
I've found ones on ebay:
Hello,
Thank you. Yes I ordered the H4 bulbs with the P45t mounts and inserted them after the garage seemed to not be able to get the classic bubble ones and then took to the ITV to retest the lights and then we discovered the bracket was missing which makes the stream of the light not right. I wanted to order the classic bubble ones as well just in case that added to the issue.
