imps500
Hi Guys,
I am new here. I tried searching for similar threads, and although I find issues with front headlights staying on after the car is switched on, its not quite the same issue as I have, so hoping someone can help me.
I have a 2008 Fiat POP, recently when I switch the engine off, a few minutes after, both the front and rear headlights switch on. They then either stay on, or switch off and then come back on, draining the battery (I currently have to hook/unhook the battery everytime I take the car out). I changed the battery previously before I knew about this issue so know this is not the problem.
I had a look at the rear hatch wiring, but the grommet and factory tape are in good condition (although I do notice when I push-pull the rubber grommet back into the tailgate hole that it then locks/unlocks the rear boot. Also if I switch the engine off, but leave one of the doors open then the issue does not occur. I've read on other forums that this may be caused by a whole host of issues including failed BCM's and relays. However, I was hoping someone had a specific remedy for this issue.
Regards
Alex
Regards
Alex
- Model
- Fiat POP
- Year
- 2008
- Mileage
- 115000
