General fog lights
General fog lights
ap07aaa
The fog lights coming on when steering corners is good idea i think.
Can you turn it off? The reason i ask is because i have had several drivers think i am flashing them!
No, and the other drivers are fools. Unless you're driving towards them as if you're on a slalom the corner light will only come on as you go into a corner, or go off as you come out of a corner.
In my experiance this isn't the case. If u indicate to turn and your speed drops below aprrox 20 -25mph the turning lights come on whilst still in a straight line which can give oncoming traffic ''the flash effect''.
If anyone thinks one fog light coming on is a flash then they need their eyes tested and need to understand what a flashing light looks like.
The fog light comes on and stays on it doesn't 'flash' so where's the confusion :confused:
i did not meet any driver which complained about my fog light flashing on him
several times ppl told me that i have one corrupted fog light :p
i find this function very handy, especially when im parking my car at night, fog light seems to be much brighter than standard lights in my case :)
Can you turn this feature off ?? I like it but if I wanted to can it be turned off so it doesnt come on when turning or indicating?
actually they can be turned off (well some can)
you can pull the fuses , turn the fog lights on, this keeps both on all the time
or
Cornerning light
(activation/deactivation of
“Cornering lights”)
This function makes it possible to activate/
deactivate the “Cornering lights” (see
the description in the “Exterior lights
paragraph).
Proceed as follows to activate/deactivate
the lights (ON/OFF):
– press the MODE button briefly, the display
will show On or Off flashing depending
on the previous setting;
– press the ^ or v button to make the
selection;
– press the MODE button briefly to return
to the menu screen or press the button
for longer to return to the standard
screen without memorizing.
out of manual and havent tried it myself
or
Cornerning light
“Cornering lights”)
paragraph).
selection;
This method was posted on an earlier thread.
It's caused a bit of confusion as I believe all of those that have tried it have had no success.
We've yet to find a Bravo where this menu option is available :confused:
