I and others have given advice on this subject before.
Parts can be replaced , but need more detail as to what is the issue, as some of the catch/lock parts are in short supply , but are similar to other van makes.
Often adjustment of door position helps.
Thank you for the reply.....I have replaced the top rod
I am now having problems with the catch that is rear of the sliding door as there is a gap and it is not shutting propley
I have often had to fix doors that have come out of adjustment as they are a heavy door and not always slid gently by operators.
Does the front of the door line up with the two metal pyramids into the spring loaded plastic buttons.
With all the runners/guides oiled can the back lock line up if helped by pushing back of door to help shut or is it out of line.
If yours is a full height door the top lock is not adjustable but the bolt/peg in frame can be slackened and moved to take up some adjustment.
