How old is the 500.? If it's over 6 years old the earth strap from n,s,f chassis to gearbox will probably be in poor condition causing low charge rate and not recharging the battery fully.
You have to rule out the basics before you spend a fortune on a steering column.
If it was my car I would replace the earth lead I mentioned before to rule it out. (Start with the cheap and known issues first) They're common for failure so it will need one before long anyway.
If the fault persists after all I have said you need a diagnostic check on the steering system. Ask for a print out with the fault code. Choose a garage with Fiat experience, halfords would not be my choice.
Any pictures or advice on where it's located. Car failed this morning 2c, warmed up for 5 mins no luck. Working now 11c. Driving me mad.![]()
Answers to question.
What fault code is stored in the steering system.?? - Not sure bloke who plugged computer in said internal fault.
Has the earth lead on n,s,f chassis to gearbox been replaced.? Not that I am aware of.
Is the battery correct and in good condition.?? (Correct CCA rating) Yes, brand new from halfords. It is the right battery.
Has the charging system been checked.?? (Under load-lights on etc) Not sure what you mean by this
Are the tyre pressures correct.?? yes
