Sprocket in a pocket
Hello. I encountered a problem with EPS and I am trying to solve it myself. My 2012 Abarth 500 was kept in the garage during the winter time and was not driven for several months. When I tried to start it, the battery was dead. It showed only 4 volts. I charged the battery and the car started fine, but there were EPS and ESC lights on the dash. The dash told me to have the power steering checked and that the hill start is not working. OBD throws C1002-17 code, regarding torque position sensor. I thought maybe the old battery does not have what it takes to feed the EPS so I bought a new battery, but the problem persists.
After changing the battery, power steering came back on vehicle start a few times (it would last around 5-10 minutes until it was gone again). Now the steering wheel is hard at all times, won't even come back for a short period. So I started digging. First I went to the dealer, hoping that the EPS needs calibration. They charged me 62 euros for "diagnostics" just to read the code and tell me to get a new power steering column for 5000 euros
Essentially they read the codes and did not even try to look deeper.
After some investigation I found some forum threads where people shared that very rarely the EPS column itself is the problem, rather it's usually some electrical problem like grounding (for example: https://www.fiatforum.com/threads/eps-electric-power-steering-faults.491623/post-4623018). It would make sense that some cables could've oxidized. The car was sitting in a wet garage for some time until I relocated it to a ventilated one.
Today I removed the main engine earthing strap and it is really "green and red", so I will be replacing that. I was wondering maybe someone knows where is the earth point for EPS itself? I would like to especially pay attention to that place and clean it well. I do not believe that my EPS column is at fault because the vehicle was just simply sitting still, not much of wheel turning was done during that period of time...
- Model
- Fiat Abarth 500
- Year
- 2012
