Technical Engine Spluttering
supervampi
Hi my petrol 1.2 53 plate punto splutters when the engine gets damp and theres like a sulphur smell like struck matches comes from somewhere,the top of the air filter box gets wet?
The ring in the airbox is annoying because that does fill up with water alot.... espicially when it rains
So it airbpx gets wet so does the hts and plugs
On the coil pack housing is the cylinder connectionn order for the hts I think its 2314 have a look u will see it
But splutter id tackle hts and plugs
A full cat or petrol is bad news, once misfires cured get a dose of posh petrol in and give it a blast to
A get upto temperature
B get it cleared out
When I dropped a coil I could smell and see excessive out the exhaust as it cleared luckily I didnt kill my car
Ziggy
you need as suggested to change the sparking plugs but also the ht leads
if you dont and you carry on then your ecu will pop next
puntos dont like poor leads and plugs
