Splash9
I've got an F reg Tipo which has had electrical problems lately.
The car itself has always been a superb starter and runner but recently after a few miles or so (it can be 3 miles or 30) the battery will start to drain. The dash, being digital, will dim and eventually the radio will fade too low to hear. At this stage the engine will also become lumpy and lose power as it struggles to fire sufficiently. Once the engine is running it will usually continue until switched off but should you try to restart it the battery will appear totally dead. Should I try to start it a few hours later or the next day it is quite likely to burst into life again. As a result I have taken to carrying around a spare fully charged battery which will always start everything up again but this is obviously less than ideal.
The dashboard also dims whenever the lights or any other high load item ie heated rear window, gets turned on.
I have changed the alternator twice for exchange scrap items but the same fault persists, so the symptoms suggest something other than the battery or alternator. An earthing fault appears most likely but which, where and how do I isolate it ??????
please, please help ...
Pete
Pete
