O.K. Guys..... I have an ongoing problem with the ECU on my Doblo 1.9 120 .
The history is : The ecu was re-programmed (twice) a while back (because the 'technician' - hah ! didn't do it right the first time . This was because it had had the dpf deleted , and presumably had the ecu remapped to suit.....When it came to MoT time the tester ( who had tested the car twice before , with the 'deleted' dpf in place) decided that he didn't like seeing the deleted dpf and I had to buy a new dpf and hence reprogramme the ecu back to 'standard' !
Now , coming up to date : I have had my local mechanic gut the dpf again ( this time with no outward signs ) and he had real problems re-mapping the ECU again..... He thinks that the ECU has been 'corrupted' somehow.... So the ECU was sent of to Veizu Technologies in the midlands and was again re-programmed to take account of the dpf delete and a EGR delete .
It has now developed a fault where after running for a while , the engine will start 'hunting' and throwing a LOT of white smoke out ...... We think that it is trying to do a regen , when there is no regen anymore and my mechanic thinks that the old programming is trying to reassert itself , hence throwing up these faults ! When it does this , if the engine is switched off and restarted , it seems to reset something and runs normally for a certain time , before it does it again !
He has suggested getting a replacement 'matching' ECU that can be properly programmed to my car..... Apparently , certain numbers on the current ECU have to be the same as any replacement ??
Does anyone have any insight into this problem ,please and can help me get this sorted once and for all !!?? ..... Maybe someone has a suitable ECU for sale ? .... We think that the original ECU is so screwed up as to not be able to take a re-program properly ! ...... I need help !!
- Model
- Doblo 1.9 120 mpv
- Year
- 2006
- Mileage
- 135000
