Update; My Ducato is running again as it should.
I think I need to give the full story here.
About year ago on the highway I suddenly lost throttle. When moving to the shoulder it picked up again, however 15 mins later same thing and much worse now. This happened close to an exit so I brought her to a parking lot and called ANWB (dutch AA). Engineer arrived and car started without issues so drove home. Problem showed up maybe 3 times later but only when starting, annoying but not very disturbing. It would just run idle and not respond to throttle. After one or two repeat starts all would return to normal.
This happened again last week on my driveway and engine stalled after running for about 5 seconds. Tried multiple times to no effect.
Called AA again and engineer plugged in his diagnosis system. His analysis was that it could well be a throttle signal issue as it showed quite large voltage difference over 2 the two pot meters, however a bit unsure because the engine stalled. Engine did start once. Later tries again unsuccesful.
I ordered a new pedal but had to wait a week for delivery. In the mean time I found a used pedal, installed it and problem not solved. This morning I got the new pedal and figured that I should at least give it a try. Surprise; everything worked again!
Anthony, big thanks for your assistance. Hope my problems are over now, but great to see this forum with people helping!
