WayneNZ
HI All.
I am having trouble starting my Ducato 2.2 2022 9 sp auto camper. It has had water drowning. I've replaced BCM and airbag system.
The engine turns over ok but tries very lightly to fire on one cylinder. No fault codes present.
Rail pressure ok. Crank speed ok. I checked fuel injector supply voltage at 4.93v which i feel is too low to fire the injectors. My ECU may be cooked. Supply to the ecu seems good.
I would think the injector voltage would be at least 12volt to fire the injector.
Any idea on what voltage should be?
Cheers.
Cheers.
