I have a work van is Fiat Ducato 2010 2.3JTD 120 (IVECO engine) it has been a nightmare lately because I had a issue with start up, when the glow plugs warm it starter but sometimes it refuse to start and leave like 20 minute later and it start!
I have been fit a new fuel filter, new glow plugs, new fuel pump from the tank (high ohms is faulty with motor make a terrible noise) still had the same issue and I have been diagnostic to find a no faulty code, the injector pump and the injectors are function well by chart graph on MultiECUscan.
I felt is the last chance is try to replace a new glow plugs relay which is location on passenger side near the headlamp.
I have been look at it the relay, the numbers printed has worn are hard to reading. I thought it would be a easier to find only one relay for 2.3 but it wasn't there are two types of relay with different codes for 2.3 engine
why are those two relay have different codes? there is only one engine 2.3 it should be one type of relay
What will happen if I fit wrong relay?
