VanDerErrol
Hi all, after searching around and not finding anything that matches my problem(s) I've decided to seek your advice before talking to a garage.
Background:
Ducato 2018 Dual EGR (x290?)
OBD2 reader = Topdon Artidiag 500s
Fault codes experienced:
I know this will not pass an MOT (now due).
What I've tried to date
I'm thinking that there's a continuity problem on one or more wires now or corrosion somewhere..
So, I'm after guidance on where there may be common points of failure in the wiring, and testing procedures, please.
I think the attached diagramme is relevant?
Red dotted lines indicate what I think is the wiring route.
Many thanks for any help received.
Background:
- C0034-29 (Speed Sensor ront Right Fr - signal Signal invalid)
- U1712-87 (Steering Angle sensor on node C CAN - Missing Message)
- I cleared the codes and they stayed.
- I tested the FR speed sensor and got no voltages on spinning the wheel - I changed the ABS sensor on the FR wheel. (No change, and in retrospect a dumb waste of time)
- (I will write up a guide to doing this and the problems I encountered, and share, though...)
- I have replaced the engine earth strap, and added a supplementary strap.
- Model
- Ducato
- Year
- 2018
- Mileage
- 79000
