Fiat punto mk2 (188) 63cv 8v 250.00km gasoline.
The problem is that the warning lights of the abs, heating resistance and hand brake remain on. The car is gasoline and has no abs.
It was a rainy day and a lot of humidity. The bulbs are on with the ignition and car running. If I turn off the engine and take out the key, the light bulbs stay on for a few more seconds.
I have removed one by one the dl fuses inside the car, those under the wheel and the bulbs do not turn off or just do it with the fuses of the instrument panel. I have disconnected the battery for several hours and it does not go off.
If I put the parking brake, the bulb turns on 100%.
Thank you.
Thank you.
