Technical Dash lights going crazy!
addscalamity
London
Evening all,
Got a 2015 lounge and the dash lights have gone a bit crazy.
Basically all the lights on the dash, EML, seat belt, airbag etc are on all the time, but very dim. Then when I indicate right, they all flash with the indicator!
Any ideas would be much appreciated.
Model
1.2 lounge
Year
2015
Mileage
50000
Evening all,
Hi, 🙂
almost certainly the wiring to the Rear Hatch has worn.. And several wires are touching.. Or broken 😕
Other option, Scuttle Drains are blocked.. And rainwater has got into the electrics 😉
SEARCH on here for the relevant info
Duckbills : scuttle drains
Maybelline : rear hatch wiring
Do let us know what you find 👍
The fix could be more of an issue I suspect, once the display is "cooked" due to the rear wiring, when people have reported lights flash with indicator it seems the only fix is a replacement speedo but only once the rear wiring has been correctly repaired
