Technical Cruise Control
Stephen Cowdell
West Bromwich
I have a motorhome on a Fiat Ducato base, 9 speed automatic, year 2024.
Has anyone had this issue:-
Driving on CC for many miles no problems then all of a sudden the cruise control cuts out, it’s as if I have touched the brake, on the dash it says CC cancelled.
Thanks in advance, Steve
Model
Fiat Ducato 2.2 automatic
Year
2024
Mileage
4500
Many years ago I had a similar fault which was traced to a faulty foot brake switch. I would change this switch to eliminate it.
Hi Steve
I am having the same problem, sunlight t68 motorhome fiat ducato 2.2 140, 9 speed auto.
did you resolve the issue
regards les
I had this problem and if was caused by a clogged DPF. Basically the ECU will cancel the cruise control at the slightest hint of an issue, it could be any of a number of things. Check with an OBD reader for any pending error code.
