Technical crankshaft position sensonr
huaweiideos
Hello everyone and happy new year.
I need your help, 1991 fiat Tipo 1.6 cat i.e won't start, some people told me that it should be caused by crankshaft position sensor, does anyone has info or can tell me the location of that sensor, how can I find/replace it...
P.S when I try to start the car, ignition coil gives just one flash and than nothing, I tried to start car with new ignition coil, but it's same.
the sensor will be at the bottom of the engine,
partially hidden by the belt pulley,
https://www.fiatforum.com/attachment.php?attachmentid=43138&d=1210200406
2 x electrical cables; :)
1 , oil pressure sensor
2, Crankshaft Position Sensor ( visible in photo)
GENERAL info - not too sure on the tipo
Charlie
Thanks for your quote, I replaced the crankshaft position sensor, the car trying to start, but still won't, there are several bangs from the head of engine, smoke and fire comes from air intake pipe but the car won't start...
that is because the spark is happening at the wrong time,( when inlet valve is open) :(
check timing marks / cambelt 1st, ;)
Charlie
I think it's beacause of petrol in engine, the sparks are getting wet... I replaced them and dried but there was to many petrol inside and the sparks are getting wet again... I'm going to try jump start on long distance
the car is sparking at the wrong time..,:eek:
check the timing, of injection + spark.. also the valve timing.., ;)
