Technical Couple of questions from new 2024 500e owner
ThatchVdB
Colorado
1. what is a "pebble fob"? I see several references to such a thing on this board.
2. Is there any way to dim the instrument cluster (not the Connect display)? I find it way too bright at night.
Thanks!
Thanks!
1 The 'pebble' fob is just a wearable key with no buttons. Wear around your neck and car will unlock when you operate the doors and lock when you press the door on the drivers door. It does not lock by itself. Boot will open and re-lock without opening doors.
2 You can set dimmer levels for light on and lights off using the menus on the dashboard behind the steering wheel, not the central screen. You cannot set the two screens to different levels. They do not adjust to ambient light. That is very stupid of Fiat!
Both assuming the USA version is the same as the EU version.
