General correcting mileage on digital clocks
Put my old clocks in, seems the ecu has added the mileage of both onto my old clocks so they're now on 47k :(
the new one is back in now and still on 2800 miles, the option yani says is there to change the mileage isn't there, can't say i'm impressed with FES at all!
The option is there somewhere I can remember seeing it.
Think select the correct car then dashboard, then I think its the end tab.
Good informative thread but....
Just to some it up. To remove faults and correct mileage correct/flashing mileage. I will need the full version of Fiatecuscan and this cable ...
http://www.ebay.co.uk/itm/V1-4-ELM327-OBDII-OBD2-CAN-BUS-Diagnostic-Scanner-USB-/280708396116?pt=UK_In_Car_Technology&hash=item415b863454&clk_rvr_id=267365230373&clk_rvr_id=267365230373#ht_5742wt_922
Anything else? Does this cable fit in the interior fuse panel to make these corrections?
And I can only up the mileage, not lower? Cheers
That is correct.
An elm327 cable which connects into the fuse panel in drivings side.
Can read/clear trouble codes, check system functions.
Fix the flashing odometer and rewrite mileage for lower mileage clusters.
Needs the latest version of FES full and not free version.
i have put the rev counter clocks in and my clock and trip is flashing on and off, anyone in newcastle area able to sort it for me thanks?
did you ever find out why we couldn't get it to work properly mate?
i could connect to everything else on his car but connecting through the proxi alignment it just brings up an error on the cable settings, when they're fine as it worked on my punto and connected to everything else.
i since tried it on my punto after his and it connected to mine fine.
