spleenharvester
I've been through the ringer with the coolant system on this car - 2011 Fiat 500 1.2 312 with 169A4000 engine. I have replaced basically all hoses and clamps in front of the firewall, the water pump as part of a timing belt change, the coolant pipe attached to the engine etc. All bled properly every time a change was made. I've inspected everything down to the water pump gasket to try and find any leaks and I'm finding nothing. No signs of dampness behind the firewall anywhere. There is a very small leak on pressure test when pumped up to 1.4 bar (like loss of 0.1 bar after about 15-30 mins?) but I cannot see or hear any coolant bubbling.
The issue is the car basically dumps coolant down to about 3cm below the minimum level on a short journey before stabilising, which is roughly at water pump height. Even filling it right up to the very top - it still dumps easily a half litre of coolant somewhere. After a while of running low the heater core seems to airlock and it stops blowing hot air out into the cabin, and very occasionally will throw an overheat warning on the dash, but this seems to be sporadic. You'd have thought it would be forming a puddle underneath the car or something with the amount it's losing but there just aren't any signs of anything at all.
The only things I can really think of are (a) the head gasket - which doesn't really make much sense as there's no oil in the coolant and the car is running fine aside from this? - and (b) the radiator, possibly if there's a small crack in the front of the rad it's draining into the bumper area and may not be immediately visible. But I feel like I have ruled out pretty much everything else, other than a leak in the cabin, and I feel like we'd notice half a litre of coolant draining into the cabin.
Has anyone encountered this before?
- Model
- Fiat 500 1.2 312 169A4000
- Year
- 2011
- Mileage
- 90000
