Technical Compatible Engine Replacement for Fiat Punto Jet Black 2 (2014) - Advice Needed
Ajaytom
United Kingdom
Hi everyone,
I own a Fiat Punto Jet Black 2 (2014, 1.4L Petrol, Manual, VIN: ZFA199000P063429, Engine Number: 07409004) and I need to replace my engine due to a mechanical failure.
I understand my current engine is the 1.4L FIRE (Engine Code: 350A1.000), but I want to confirm:
Which engine models are a direct replacement without requiring major modifications (ECU, mounts, wiring, etc.)?
Would an engine with code 350A1.000 from another Fiat model (e.g., Fiat Punto Evo, Fiat Linea, Fiat Fiorino) be fully compatible?
Are there any other recommended engine codes that Fiat used in similar models that could fit my car?
I’d really appreciate any guidance from those who have experience with engine swaps in the Punto models. Thanks in advance!
Swapping a mount or sensor is not a "major" mod!
Real question is, WHO will do the engine swap?
1. You? Don't do it (if you have such simple/silly questions, "problems", this is not a task for you - straight technical fact, not an "attack").
2. Mechanic, professional shop? Leave this to them (they will figure out cosmetic differences).
This unit was also installed in: Doblo, Qubo, Grande Punto, Idea, Albea...
