Oh how I love forums, everyone has there own way of thinking and most of the time it gets off topic. Very entertaining for the Friday morning.
RaR
Me too
No steam coming from my ears
RaR
Erm, colder weather DOES increase the performance of a turbo engine...... colder denser air means more oxygen to burn which means more power. If the car has an intercooler then the effect is magnified as there's that cooler air to cool down the intake air even further.
Ok i'll drop my case.
Am I right in thinking that there is more reason to do this with a diesel? Lower operating temperature (longer to warm up) and the bigger risk of the fuel freezing?
Definitely with you re: warm up time. The fuel _shouldn't_ freeze unless the filling station had some old-stock summer diesel in it.
Blank off the middle half of your lower grille with duct tape or similar during the winter months, the car will warm up much quicker and save fuel as well as emissions and wear and tear.
People used to fit these radiator blinds all the time, nowadays everyone just expects the car to take care of everything... but there's a big difference between thrashing around Sicily in August and pootling around a chilly Britain in December.
Yeah, I think all diesel after a certain date has to be of a different composition to avoid the fuel solidifying. That said, if it's -something silly the fuel is still going to solidify!
That was in the day before thermostats where the coolant continuously circulated through the radiator surely
It doesn't solidify Maxi (well i suppose it could if left long enough at a cold enough temperature it "gells" or "waxes" when parts of the Diesel begin to sepperate out and cause crystals to form These usually then block the fuel lines/ filter until it warms up and "melts" (had fun last winter with the forklifts at work..... )
EN 590 is the spec that covers Diesel and its classed A to F Uk winter diesel is usually class F which is -15^C (Cold Filter Plug Point)
Do you think on a fuel station forum there is a thread called "winter diesel" with people discussing which winter diesel to choose, and with this mild weather if they should hold off?
I wonder if they will have their own version of Maxi preaching the virtues of winter diesel to the masses?![]()
