So the last couple of days have been the coldest I have had to start my car in this winter. I turn the key and manage to get the engine going but then it cuts out immediately. I wait 30s-1min try again and it starts up and im on my way.
The EML light is now on. Whilst on lunch at work I managed to get out and check the battery albeit its probably about 5 degrees warmer at this time.
12.6V with engine off
14.3V with engine on
14.2V with lights and blowers on
When I got home I checked the error. It read
P0351 - Coil 1 - Anomoly found on the indicated line for the ignition coil, Check continuity and insulation of the indicated wire
P0352 - Coil 2 - same as above
I cleared the faults, had no more issues with starting until this morning where it happened again.
So what do you think it could be? Is it that my HT leads just need replacing? I don't think they've been done in a while and I know my sparkies are nearing 2 years/20k
Thanks guys for all your help in the past!
