Technical coil dizzy wiring help...
MCA Sports
Hi all.
I have an MCA sports i will be restoring, but have 2 engines - the one in it with a manual starter without solenoid and normal coil, and a donor scrap chassis parts which has a solenoid starter and what looks like an electronic looking square coil? But that engine is missing the dizzy etc.
i would like too use the later system if i could..so my question is........
is the electronic looking coil just a newer kind of coil? or some electronic ignition? so does it work with a normal dizzy with points or do i need to find the correct dizzy for that system??
ta..
Mike.
xxx
