edmundhill685
- Joined
- May 26, 2007
- Messages
- 40
- Points
- 10
I have foolishly left my panda up under the trees in the grass for 4 months, having bought myself a 1979 Citroen Dyane.
I started the car today and everything runs smoothly all the electrics work etc.
but when i pushed the clutch pedal down (it was very stiff to do this) it would not return. I released the clutch cable (which works fine) and sprayed the pivoting end of the big metal leaver with WD40. This lever can be moved slightly by tapping with a hammer, but doesn't seem to want to come loose.
Has something nearly seized? Do i need to take apart the transmission? (if so it's off to the scrapyard if no-one wants it).
Should i just continue to attempt to lubricate it from outside with penetrating oil?
