Technical Clutch bleedingfiat panda twinair
Martin g hogg
Falkirk
Hi
Are there any tips on bleeding the clutch on a fiat panda twin air .hd pedal down and gradually looses clutch but no leaks in system new master cylinder and slave fitted pedal returns fine
Hi
Generally if no external leaks or loss of fluid and if clutch pedal held down with car in gear it looses effect and then tries to stall or you cannot pull gear lever back to neutral, then it points to a duff master cylinder, even with a "cheap" new one.
Sometimes with brake and clutch master cylinders I have seen when observing the fluid level with lid off and engine switched off, that the level goes down a little as pedal is pushed and held which is normal, but that without moving the pedal the fluid in reservoir returns caused by fluid coming back past the pressure seals in the cylinder.
