Technical Cluster upgrade
Wakefield
Hi is it possible to replace the speedo from a 2022 ducato 2.2l partial lcd cluster type and put it into a 2018 ducato 2.0l if so as any one done something similar thanks
From this to this
Hello,
I assume it won't be possible, as there was a facelifting between those dates and much of the electronics have changed, most probably also the BCM including the firmware (or software) used and the looms.
Related . . .I have a motorhome with the later cluster pictured, with the Speedo engraved in kilometres per hour. I'm hoping that a straight swap of the full cluster, like-for-like, with one engraved in miles per hour, will be seamless. Any thoughts on that swap?
PS - I've been in touch with Lockwood's about just fitting a new speedometer dial and, sadly, they don't have the tooling for that variant.
Thanks (and apologies for piggy backing on a thread).
Nod
