General checking gearbox oil
williamb
colne
can anyone tell me how do i check oil level in gearbox 2.8 jtd 2004 model. thanks:slayer:
Check Following:
all versions
- Position the vehicle on a lift.
- Raise the vehicle.
- Remove engine shield.
- Undo the gearbox casing drain plug and collect the fluid in a suitable container.
Do not let the oil disperse into the atmosphere because this could cause pollution.
- Clean the drain plug.
- Screw in the drain plug and tighten it to the recommended torque.
- Introduce the oil into the gearbox casing via the gearbox oil vapour breather opening.
2800JTD
Description Qty. Component Type Classification
- 2 Litres. GEARBOX OIL
As there is no opening for checking the oil level, stick to the quantities of oil recommended above.
- Replace engine shield
- Lower the vehicle and remove it from the lift.
