liferichcashpoort
- Joined
- Dec 22, 2014
- Messages
- 6
- Points
- 2
Hi all,
35 160 M-Jet / 3.0 / Auto / 2008
I have been getting "Check Glow Plugs" alert when starting and the glow plug symbol flashes for a few minutes after starting.
I'm new to this vehicle, and to diesel engines, but quite experienced on petrols.. so basically know what's going on..
However, I have done some exploratory nosing around and internet searching and now I'm feeling fear, so I hope you can answer some questions:
1. "Check Glow Plugs" does this really mean replace one or more? I'm trying to get to them to test them with a multimeter, but so far haven't got to them!
2. Do I really have to take most of the front of the vehicle out to get to the glow plugs? including the throttle body? I have downloaded the fiat cd thing and it says I do, is there a trick?
3. Risk of them snapping if I take them out? Is this common, and should I bite the bullet and take it to a fiat dealer to do?
4. Water ingress... hence my concern about snapping, there is too much water in the engine bay and I have read threads on here, and now have that 'sinking feeling' that there is more going on here. I have a little standing water around the right most injector and some signs of rust.. from what I can see, this is primarily because there is a well in which the injectors sit, the glow plugs are round the front and probably won't have had water around them ?? but others have mentioned it..
The water ingress issue seems to be a bad one, which Fiat should have done a recall on, is the experience that you just have to fashion something yourself?
I'm a long suffering VW van lover and am used to bill after bill on that van, but it's 30 years old, I really don't want to go down this road with this blooming expensive van - I thought I had an easy time coming with this machine!!
Sorry turned into a bit of a rant, adding to my pain is it just had a service and an approved dealer, who wouldn't look at the glow plug issue, but still charged £400 for an oil change minor service!!!
ARGHHH!!
thanks in advance all!
Andy
ARGHHH!!
Andy
