Greasytrucker
Established member
Looks like plenty of water ingress there
Fingers crossed when you get it all dried out all will be OK. Just hope it’s not fried anything
Fingers crossed. I will keep you updated.Looks like plenty of water ingress thereFingers crossed when you get it all dried out all will be OK. Just hope it’s not fried anything
you could always use an ordinary hair- dryer to evaporate as much water out of the fuse box and connectors as possible! needs a bit of patience ( and not to higher heat setting) but gives you a good place to start when using the above mention sprays!Thank you buddy. Makes me feel a bit better now as I was thinking I've used the wrong stuff![]()
Agreed a flash exposure wont hurt but given time to"soak" the solvent can cause permanent damage to the material requiring replacement!Elastomers in the electrical system and suspension are oriented towards the water based chemicals (water, salt, glycol, alcohol, washer fluid, brake fluid etc.).
Oil, fuel, grease - different types of "rubber" (and those are in the engine, gearbox obviously).
Traditional 2 groups of elastomers.
Yes, nowadays we have modern materials, that can be suitable for both "environments", but be careful.
You can clean almost any type of rubber with random chemical, solvent, whatever, but the exposure time should be minimal (seconds, minutes max.), not soaking for hours.
I did think that then I thought I might get my leaf blower on ityou could always use an ordinary hair- dryer to evaporate as much water out of the fuse box and connectors as possible! needs a bit of patience ( and not to higher heat setting) but gives you a good place to start when using the above mention sprays!
Just make sure it’s not on suck or you might need a new ECU!I did think that then I thought I might get my leaf blower on it![]()
Yes finally that awful dash light has gone. I'm charging up the battery at the minute as its pretty much dead with the constant turning of the key haha. Fingers crossed fir later. Will keep you postedIn my opinion compressed air should be better than hot air, because in closed boxes / cases (ie. relays) the water won't have enough room to evaporate. It will just condense on top and then flow / fall down on the contacts.
The blinking on the dash doesn't look goodBut I can see that the immo light switched off
